Post by hondacat on Nov 14, 2015 7:54:46 GMT -5
still working on brake hose components and fitting but the hose machine is up and running we just made out first set of auto pilot hoses we are also going to be able to make transmission cooler lines and power steering pump and cooler lines (marine) some of these lines that are no longer available from the OEM manufacturers FAQ> yes these are the same hoses used in the bass boats
Post by striper2300 on Nov 18, 2015 8:17:30 GMT -5
Frank NOW! you won't hear when you try to order " we don't have in stock cause it's winter and don't want to carry inventory"
Joe
Post by hondacat on Nov 19, 2015 8:06:35 GMT -5
thanks for the post Joe you know your boat was the last straw in dealing with the endless excuses from suppliers why did not have the hose's we needed to finish a job "Oh you can always use a longer hose" well that may be what SHE says but not the case with auto pilots some hoses have to be specific lengths for components to work properly so Joe its all your fault we had to bu this expensive equipment . you actually just helped us make a decision we have avoided as long as we could stand it If we would have had this equipment we would have delivered your boat to you at least 3 weeks earlier. there was just no way we where going to put the wrong hoses in there just to get it out the door 3 weeks dont seem like much but can easily have you totally miss the spring coho run !! OUCH!!!! BRINGS ME TO A IMPORTANT NEWS FLASH !! AUTO PILOT NOW !!! For the guys wanting it for spring although we can now make our/your hoses in minutes we get backed up with auto pilots every spring not to mention all the other electronic stuff guys wait till spring to finally pull the trigger on now back to Joe >>>>how do you like the auto pilot ?<<<<<< Joe has 2015 HEWES 190 SEA RUNNER HARD TOP WITH a Garmin reactor AP with the smart pump It runs the big motor is set up with a tie bar for the kicker we have installed a troll master to control the speed on the kicker so this set up can be used for both going out to the fishing spot controlling the main motor and control the steering on the kicker at under 1 mph because this unit is getting thru some magic set up programming by the wizard of AP Derrek getting its speed from a high speed network thru a Garmin 5212 head unit i know it is a sweet set up but like to hear from Joe how he likes the way it works not A BAD FISH FOR FIRST TRIP !
Post by striper2300 on Nov 20, 2015 9:27:32 GMT -5
Frank
IN ONE WORD "GRRRRRRRRRRRRRRRRRRRRREAT!!!!!!!!! You know how much fun we've had. You know the old saying "you get what you pay for" well' I got what I paid for and couldn't ask for better, fantastic setup and excellent installation, top shelf for sure.
Post by hondacat on Nov 2, 2017 7:48:56 GMT -5
still working on brake hose components and fitting but the hose machine is up and running we just made out first set of auto pilot hoses we are also going to be able to make transmission cooler lines and power steering pump and cooler lines (marine) some of these lines that are no longer available from the OEM manufacturers FAQ> yes these are the same hoses used in the bass boats CHECK PU THIS VIDEO CLICK LINK BELOW !!!!!!!!!!!!! youtu.be/-PDSHeFhKFA?t=62
