Post by hondacat on Oct 19, 2011 6:57:22 GMT -5
"Whats between YOUR BOAT and The BOTTOM of the lake" Been wanting to do some thing like this for a while could not find a good title till NOW This section will be about what to check to keep your boat off the bottom What not to worry too much about and what needs to be taken out of the water NOW! more to come will be updating this so check back often. The out side strainer cover was sheared off for quite a long time by the looks of all the green corrosion where the rest of it was supposed to be either by hitting some thing wile the boat was under way or from the trailer itself the only thing holding it in the hull was the sealer itself if you ever sea a sea cock leaking around the bond between the hull and the fitting or the it is loose the boat needs to be pulled and repaired if it is both loose and leaking get it out of the water quick
Post by striper2300 on Oct 20, 2011 9:36:05 GMT -5
Very interesting Frank, I played the lotto but no winner so I'll just be glad I didn't go swimming
