Post by hondacat on Apr 29, 2014 20:51:06 GMT -5
Almost done Have to remake the cabinets in the back and install the floor turned out realy nice Installed a ski pylon that is removable for the kids to do some tubing easily removable for dad to do some fishing
Post by hondacat on May 10, 2014 16:40:08 GMT -5
Post by hondacat on Dec 22, 2014 20:09:34 GMT -5
follow up important information and pictures since we only do a few of these each winter and can not do all of them that guys want done I encourage the guys that have the ability to do this kind of work for them self follow up from this post www.glanglerforum.com/forum/showthread.php?18743-Lund-transom-replacementrecently a couple guy have tried and during the process of making the transom while curing the transom board have warped on them bad enough they could not get them into the boats though I should follow up with some pictures of the actual gluing process we use that eliminates this potential problem also we use west system epoxy sealer adhesive tends to warp less than fiberglass resign never use any woods treated with copper oxide (green wood) the copper oxide with react with the aluminum hull and rot holes in it FAST often marine plywood decking is treated with copper oxide
Post by hondacat on Dec 22, 2014 20:10:08 GMT -5
since we only do a few of these each winter and can not do all of them that guys want done I encourage the guys that have the ability to do this kind of work for them self follow up from this post www.glanglerforum.com/forum/showthread.php?18743-Lund-transom-replacementrecently a couple guy have tried and during the process of making the transom while curing the transom board have warped on them bad enough they could not get them into the boats though I should follow up with some pictures of the actual gluing process we use that eliminates this potential problem also we use west system epoxy sealer adhesive tends to warp less than fiberglass resign never use any woods treated with copper oxide (green wood) the copper oxide with react with the aluminum hull and rot holes in it FAST often marine plywood decking is treated with copper oxide we leave the plywood clamped to these large steel tubing for one week in a warm environment ( needs to dry/cure completely) before we remove it and seal the sides and corners with the epoxy sealer let it dry for another week then install it
