Post by HONDAM on Oct 28, 2014 19:33:12 GMT -5
For a long time I was frustrated changing oil on Honda engines, it usually made such a mess. The little lip they build into the midsection to help direct the oil wouldn't help much on its own and oil would just cover the side of the engine. There has to be a better way right? Well here is one, I use a flexible funnel and a pair of vice grips. Works like a charm and usually don't spill a drop and no mess.
Post by kingseeker on Oct 29, 2014 19:31:36 GMT -5
That's a great tip Ryan . Have you used that funnel when changing the oil filter also?
Post by HONDAM on Oct 30, 2014 21:13:26 GMT -5
No although it probably would do a good job for that. I usually just shove a rag under the filter.
I usually try not to run the engine before changing the oil, makes changing the filter less messy.
Post by hondacat on Oct 31, 2014 4:50:29 GMT -5
thank you Ryan for sharing great tips some times Ryan would even help his Brother ! These boys of mine been helping me fix stuff since kindergarten it all started with just holding the flash lite
