Post by hondacat on Jun 1, 2011 19:10:53 GMT -5
The Honda Product line has a Proven track record for the ultimate in reliability and fuel economy this is not with out some some hurdles to jump and bridges to cross Like for example the Honda 8hp and up with power tilt has this huge transom bracket that's got what it take to keep the motor tilted up when running on the main motor this delivers one tortuous beating on the bracket this huge heavy duty bracket is built to take it but it creates another problem There is NO fixed bracket on the market made to accept the big foot print this heavy duty Honda part needs it would be nice if there was some sort of bracket you could just buy and bolt on but there is just nothing big enough in a fixed bracket @ calumet marine we take the biggest heaviest fixed mount bracket on the market and custom fit it with reinforced transom plate to match the requirement of the boat and the motor after you get the motor all bolted on and hooked up we have to match the motor to the boat with the RIGHT prop For a kicker in most if not all cases the std prop will work but a prop specifically designed for a power thrust application will work better both these props a 7" pitch but the one with the big huge square blades is the best choice for this application do it right the first time you will be happy with the results
Post by hondacat on Jun 4, 2011 9:18:31 GMT -5
new hot set up for steering we use this one when the old style tie bar wont work especilally use full for the guy that puts his kicker on a bracket they sets the kicker motor back
Post by hondorrior on Jun 27, 2011 19:40:20 GMT -5
You are Freaking Me Out Frank! John "OLD Warrior"
