Post by HONDAM on Jan 15, 2015 17:30:06 GMT -5
Post by kingseeker on Jan 15, 2015 19:17:44 GMT -5
That looks costly Ryan glad my Hewes will never have that problem.
Post by HONDAM on Jan 15, 2015 20:38:30 GMT -5
About $3k, takes me and another guy about 3 days. The time consuming part is down inside all of the lockers you have to go pull out all the carpet and cut the walls away from the floor. This is where the factor bonds it together too and the fiberglass is only 1 layer thick. Then once your done you have to go glass it all back in put in new carpet.
Post by hondacat on Jan 16, 2015 9:29:21 GMT -5
great job Ryan another dirty job done dirt cheap around here all the dealers would have told the customer to scrap the boat you guys are obviously set up for these sort of jobs its a grim reminder of my truck the ford dealers I talked to all wanted me to trade it in " NOT WORTH FIXING" THEY TOLD ME we know that's bull shit !!!!!!!!!! THANKS FOR POSTING HARD TO BELIVE THIS STARTED WITH ELECTRONICS INSTALL GONE WRONG BUT IT HAPPENS ALL THE TIME
Post by dayoff on Jan 16, 2015 20:03:29 GMT -5
Wow, I thought this was a giant muskrat attack.
Post by HONDAM on Jan 24, 2015 17:59:07 GMT -5
Almost done Fixed the floor where we had to cut access holes to remove the glue the held the floor to the hull of the boat. Fiberglassed all the corners back together in the compartments. Put some carpet down on the floor, taped the edges to keep the glue where it needs to be. Started hooking everything back up, live wells, install fuel tank and batterys, make sure everything still works Put the motor back on Finish installing carpet in the rest of the compartments Notice everything that goes into that transom gets well sealed (pictured is the infamous temp sensor that wasn't sealed and caused a whole lot of damage) Now all that's left is some touch up on the carpet edges and a good cleaning.
Post by hondacat on Jan 24, 2015 18:23:53 GMT -5
great job Ryan looks like a new boat ! well wroth the money when it turns out looking like that! thanks for posting !!
