T290
Junior Member
Post by T290 on May 7, 2012 17:54:58 GMT -5
Hey Honda Cat, First post on your forum so here goes!! That new inlet cover for the fuel pump has resolved the leak,the old part was clearly destorted, possibly from heat and the fact it was plastic didn't help either thanks....... The question was the gas in my tank is 3 years old but stabilizer has been used last year every year I added some fresh fuel approx.15 gal. and added some sea foam for the season,what's your thoughts drain it or should I just top it off and burn it on the shakedown cruise ?? I've started the big motor to burn off the fogging oil seemed OK ......Thanks Frank
Post by hondacat on May 8, 2012 7:04:08 GMT -5
BEST IS TO DRAIN IT BUT IF IT WILL IDLE ON THE STUFF THE EASYANDFUN WAY TO GET RID OF IT IS TO RIDE AROUND TILL ITS GONE DONT RUN THE MOTOR PAST 3/4 THROTTLE THE OLD GAS WILL SPARK KNOCK AT HIGHER RPMS AND POSIBLE DAMAGE WILL ACCUR DONT MAKE ANY ADJUSTMENTS ON THE ENGINE UNTILL YOU GET PAST THE OLD GAS AND HAVE FRESH GAS IN THERE READY TO GO THANKS FOR POSTING !!!!!!!!!!!!
