Post by hondacat on May 16, 2014 7:10:19 GMT -5
We understand every one has a budget Let's talk about the cost of new VS used boats
Although Hewescraft has a transferable life time warranty This is not with out exceptions The transferable part is only transferable for 10 years it only covers the hull It's only covers the hull for 10 years from the date of the original delivery to the customer
A lifetime is that of the original buyer it's a smart move to put this warranty in a grandson or dauters name the warranty then carries with their life's If at any time the boat is used commercially this warranty is null and void There is a excaption for corrosion most used boat we see here in the mid west come to us from area where the boat where used in salt water and have corrosion issues But here in fresh water incorrect bottom paint or improper installation or electricity leaching into the water can also cause corrosion problems that will not be covered by the factory warranty A custom ordered boat that the budget can bear is truly the last boat you will ever have to buy at least in this life time
But when it comes to a budget well,we all have to,make compromises Let us help you with accurate quote on a new boat so you can weigh out your options and make your decision based on good infor that will meet your budget requirements And still get you out on the water in the safest fishing boats made Thank you for your interest in our products and services
Post by Brian knox on May 31, 2018 13:17:19 GMT -5
The thread I read did not explain if the saltwater use voids the warranty or not. Will hewescraft cover or not is the question?
Post by hondacat on Jun 1, 2018 7:34:06 GMT -5
hewes craft does NOT cover any corrosion regardless if it comes from salt water poor choice of bottom paint or electricity leaking into the hullo water
thunder jet warranty life time warranty is transferable up ten years better boat less money
