Post by bobbyg on Jun 12, 2014 9:42:43 GMT -5
Just looking to see how to install the Transducer cable through the transom and how do you route the cable over the extended transom. do you just let lay on top or do you tuck the cable underneath. just looking at not making any mistakes when I install the transducer, also it will be mounted on the starboard side due to the kicker motor. any pictures or special parts I might would really help.
Post by hondacat on Jun 12, 2014 20:41:56 GMT -5
We run it under and clamp it ever 6-8" We use a thu hull especially designed for electronics cables well above the water line
Post by bobbyg on Jun 17, 2014 13:00:06 GMT -5
ok thank you I will probably end up going this route
