paul
Junior Member
Post by paul on Jun 28, 2016 20:01:58 GMT -5
So there is a rubber part in the kit that I did not find a match for taking it apart. It looks like a miniature PVC pipe coupler boot without the hose clamps. I'm thinking it either goes on the shaft or on the water tubing.
Also I think I should replace the seal below the water pump. I pulled it out thinking this rubber part would go in there and my oil looked a little cloudy
paul
Junior Member
Post by paul on Jun 28, 2016 20:07:14 GMT -5
Sorry. This is Paul Eberhardt with the Honda 50 on the back of my pontoon that you just did the carbs on.
I got it apart and sure enough the water pump impeller was bad.
Post by hondacat on Jun 29, 2016 7:20:27 GMT -5
So there is a rubber part in the kit that I did not find a match for taking it apart. It looks like a miniature PVC pipe coupler boot without the hose clamps. I'm thinking it either goes on the shaft or on the water tubing. Also I think I should replace the seal below the water pump. I pulled it out thinking this rubber part would go in there and my oil looked a little cloudy paul sure enough every part in there has a place to be used we have the seals in stock for the drive shaft if needed is the inpeller was melted at all the lower base should also be changed this part also in stock common part needed to do the job corectly we try to keep in stock at all times frank
