Post by hondacat on Oct 17, 2016 9:29:09 GMT -5
All to common a problem often described as a winning or bearing sound these are balance shaft drive gears and fixing properly also should include pulling the power head and replacing or cleaning the oil pump pick up screen
Post by striper2300 on Oct 20, 2016 8:02:46 GMT -5
WOW!!!...........sure looks like a reason to make an appointment with CLEAR CHOICE for implant surgery
Post by hondacat on Oct 23, 2016 19:11:55 GMT -5
WOW!!!...........sure looks like a reason to make an appointment with CLEAR CHOICE for implant surgery clear choice would probably be cheaper and more help than yamaha in a case like this with some teeth implants sad but true
